TwinTurbo.NET: Nissan 300ZX forum - Re: 16600-15v02 isn't an upgrade, its old style injectors
90Z_NA_Auto
on November 14, 2022 at 12:50 PM
16600-15v02 isn't an upgrade, its old style injectors (n/m)
posted by Bernie (NoVA)
on November 14, 2022 at 12:10 AM
From what I have researched (I have a 1990 NA):
16600-15v02 replaced 16600-30P05, 16600-30P06, 16600-30P07, 16600-30P08
Replaced PTU but Idle issue still present.
90Z_NA_Auto
16:24:27 11/11/22
Ohm test your fuel injectors. (n/m)
22:44:57 11/11/22
Re: Ohm test your fuel injectors.
90Z_NA_Auto
07:15:35 11/12/22
00:10:12 11/14/22
Re: 16600-15v02 isn't an upgrade, its old style injectors -
90Z_NA_Auto
12:50:05 11/14/22
Does not matter, it's still old style injectors.
20:44:00 11/14/22
Re: Does not matter, it's still old style injectors.
90Z_NA_Auto
11:11:01 11/15/22
I would recommend this:
01:53:15 11/17/22
90Z_NA_Auto
11:17:58 11/15/22
90Z_NA_Auto
11:45:49 11/15/22
90Z_NA_Auto
13:02:36 11/15/22
90Z_NA_Auto
09:21:51 11/16/22
20:58:37 11/25/22
You said you saw corrosion on the connector?
Polishzx
19:12:51 11/13/22
Also make sure to use some dielectric grease on the injector
Polishzx
19:35:26 11/13/22
Not really needed on updated old style connectors if
00:11:08 11/14/22
I even put a small dab in my new-style injector connectors
Polishzx
13:35:34 11/14/22
Re: You said you saw corrosion on the connector?
90Z_NA_Auto
12:41:35 11/14/22
Got it, I thought you meant in the injector connector.
Polishzx
13:34:53 11/14/22
